vinyl floors
Old 05-22-02, 04:09 PM
lafawn
vinyl floors
i would like to know what is used for the permanent coating on a vinyl floor
Old 05-23-02, 03:24 PM
T
Vinyl wear layer
"The most common resilient floor manufacturing process is plastisol spread coating. This method produces a multi-layered construction comprised of a backing, PVC foam core, decorative layer, clear PVC layer and, in some cases, a urethane sealer." Flooring: Resilient Flooring. Retrieved 23 May 2002. http://www2.exxonmobil.com/Chemicals..._Resilient.asp
Old 05-23-02, 03:34 PM
lafawn
thank-you very much for your help
