Cement Floor?
I have a small room, (10x12) that I am thinkinking about putting a cement floor in. Problems - its on the 2nd floor and im worried about weight, BUT - I only have to install 3/4 inch of cement, since it butts up against a 3/4 in pine floor, so I'm also worried about stability/cracking. Is this do-able? Am hoping to stain a faux finish when done, but thats another story. Thanks for any feedback.
TJ
TJ
A 3/4" concrete floor over wood floor would crack. The weight per sq.ft. wouldn't be that much.I would suggest 1/2" backer board and tile that would give you the desired height. and look good too.
