First Tile Job
First Tile Job
Hello,
After spending days, watching videos and reading do-it-yourself tile books, I thought I knew what to do to tile a bathroom floor. Well, after all that careful planning, I somehow managed to space the tile 3/8 instead of 3/16. I figure I have two options; replace the work already done or use a grout the same shade as the tile, which is very light. If I leave the wide spacing, will I run into any future problems because of it?
Thank you,
Martin
Thank you,
Martin
Hi
You must have liked what you were looking at as you laid the tile, so it must look just fine. No problem with that size grout joint..it's a bit wide, but no big deal. Choose any color you like for grout..the size of the joint makes no difference...you'll just use more grout.
I just needed to know that the wide grout would not cause a problem later. It did look good and that is why I probably didn't re-measure the width. Thanks for your responses. This is my first time on the forum too and I really like this.
