Replacing vinyl with tile
Old 08-27-02, 10:21 AM
Desert_Roamer
I want to replace the vinyl floor in a bathroom with tile. The house is two years old.
Can I just pull the vinyl and put the tile on whatever base is under the vinyl, or do I have to put down wonderboard before the tile?
Thanks much.
Old 08-27-02, 04:40 PM
Now that all depends. Concrete subfloor, yes tear and scrape it up, unless you want to use it as a crack suppression membrane, which is iffy!
Over a wood subfloor, install a ceramic tile underlayment! But most of all, make sure the joist and subfloor will support the extra weight!
Old 08-28-02, 08:41 AM
Desert_Roamer
I tore up the vinyl last night and found that there is particle board underneath. I think I have to pull this out also... placing wonderboard over this will raise the tile too high relative to the carpet at the door.
Does this sound like the correct approach?
