tile on greenboard?
Old 09-19-02, 03:02 AM
nesbitt
Question tile on greenboard?
I am tiling a tub surround. Because of how things worked out, I have a small strip of to-be-tiled area that is greenboard instead of backerboard. It is going to be covered with trim pieces (2"x6"). Should I prime the greenboard before I put the mastic (and tiles) on or just leave that strip of g.board unprimed? Will the primer affect the adhesion of the mastic - is basically what I'm asking? Thanks for you input.
Old 09-20-02, 07:13 PM
A
Hi
Either way the mastic will stick.....
