joint lines
Old 09-22-02, 08:05 AM
jennyanded
joint lines
Is it better to have tile laying over a joint (cement board) or to position the grout line over the joint?
Old 09-22-02, 08:41 AM
A
Hi
Sometimes you don't have a choice....but if you do...try to get the tile to cover the joint. I should mention that the joints in the cement board should be filled with thin set and covered with fiberglass joint tape.
