tiling wall around bath tub
Old 10-19-02, 09:00 AM
lindcren
Attempting to tile wall around bathtub to ceiling. Discovered that tub is tilted to outside wall and toward drain. If I follow the instructions and make the tile level, I will have an inch gap at the front of the tub toward the outside wall that would be blank. How do I fix this?
Old 10-20-02, 06:35 AM
Fill the tub with water so it has all the weight in it possible.
Pop a line level with the lowest spot. From the spot you feel will have the gap if you start along the tub. Cut your tiles along the tub edge.
