Slate tiles
Old 11-11-02, 04:57 AM
A
Angry Slate tiles
Hi,
After laying the slate tile I found that the edges of some where quite a bit higher than the others where the four corners come together. Is there any way to sand some of the high spots and not hurt the integrity of the tile to make it more even? Some of the tiles flake off very easily, or can the low spots be build up? The tile is not sealed yet. Thanks, Anita
Old 11-16-02, 12:50 PM
Azule_bahia
Theres not much you can do, unless you can chisle off the high spots (This I dont suggest). The problem is that you'll end up withdips in your floor. ideally you would want to shim the low tiles up as needed before you start mixing for the install.
Old 11-16-02, 04:12 PM
T
Because slate tiles are not gauged, each piece can have a different thickness, thus tile layout is very important and can be time consuming before the installation. Once the tile is set. It is set. Some installers recommend hand buttering the back of each tile to achieve even thickness. Tiles are fragile and tend to be prone to flaking and breaking.
Slate Installation and Maintenance
1. Natural slate is a hard dense material with a skid-resistant texture and a beautiful range of colors. Its economy, performance and durability make it a very popular choice for flooring and wall-cladding.
2. Slate is quarried in many countries and is offered in several formats: Natural cleft slate varies in thickness by approximately 1/4” (from 3/8” to 5/8”). Some slates are available ‘gauged’ – in a uniform 1/2” thickness. Others are ‘even thickness’ – 3/8” to 1/2” thick. The advantage of natural cleft slate is that you can affect color by putting either side up. The advantage of ‘gauged’ and ‘even thickness’ slates is that they are easier to install.
3. All slates should be set with a medium set mortar. Tiles can be sorted and back-buttered, if necessary, to achieve a level surface. A joint width of approximately 1/4” – 3/8” is recommended by the manufacturers. A natural gray or complementary colored grout should be used.
4. Most slate tiles are shipped loose or bundled in crates, not cartons. Buyers should add approximately 5-10% for breakage and waste.
5. Sealing of slate is necessary to improve stain-resistance and cleanability. When a natural look is desired and your floor is subject to normal soiling, apply Slate Sealer, a combination penetrating sealer and low-sheen finish. For floors exposed to food, beverage or other staining agents, apply Sealer’s Choice, a penetrating sealer with high solids content that protects below the surface. One coat of sealer before grouting makes grout clean-up easier. Remember your floor should be squeaky clean before you apply sealers and finishes and you should do a test area first.
6. If a color-enhanced finish is desired, seal first with solvent-based Stone Enhancer and then use one of the penetrating sealers above. Multiple coats may be necessary to achieve the desired appearance.
7. When a buffable top finish is desired, use Floor Shine and Hardener for a medium to high sheen. This can be applied over the Slate Sealer to maximize stain-resistance and cleanability.
8. For routine maintenance, mop with neutral cleaners such as Stone Cleaner. Be sure to remove as much of the cleaning solution as possible to prevent dirt from settling back onto the floor. A thorough scrubbing of the floor should be done occasionally depending on traffic, using a more concentrated solution. Heavy-duty cleaners will strip your floor finishes or break down penetrating sealers.
9. The products specified above are manufactured by Aqua-Mix and sold through Tile By Design. Always use products specifically manufactured for natural stone or recommended by your supplier or risk damaging your stone.
10. Since most slate is sedimentary, some flaking may occur during the first year or so. These areas should be rubbed down with steel wool and spot sealed, if necessary, to match the other areas of the floor.
Slate Installation & Maintenance. Tile X Design, Inc. Retrieved 16 November 2002. http://www.tilexdesign.com/child/tec...late-maint.htm
Go to www.stonecare.com to learn about products for sealing, cleaning, and maintaining natural stone products like slate.
