Tile subflooring
Tile subflooring
I have decided to replace carpet in my bath with tile. The house is 4 years old and has the "engineered" subflooring as opossed to plywood. A book I read said that I would have to pull in up and replace it with plywood. Please tell me I don't have too. Can I go it with plywood and cement board?
What the heck is "engineered" subflooring? Engineered subflooring has always been plywood in my thinking.
If it is particle board or OSB then it is not engineered subflooring in my learning but I wouldn't swear to it these days.
Are you talking about engineered floor joists of the plywood/I-Beam variety?
And.....what book are you reading?
If your floor joists are in fact "I-Joists" that are 19.2" on center then we need to know the sizing of the joists and how much subfloor (thickness) you have now.
If your floor joists are not less than 2" X 10" and not less than 16" on center then Todd has you on the road to a new tile floor.
Tile and subfloor
Thank you both for your help. In answer to Bud's questions, the book was Home Depots 1-2-3 Tiling. I just crawed under the house and the joists are 24" on center. The subflooring was not very well marked. It is either partical board or OSB. The roof decking is OSB (yes I was in the attic too). The only maring on the floor boards that indicated a thickness was 23/32.
