ceramic tile countertops
Old 02-08-03, 06:04 PM
erikk
i'm going to be pulling up old ceramic tile and replacing it with up to date new ceramic.do i need to replace any new plywood,or sheetrock?if the plywood is in great shape,do i need sheetrock?do you suggest floating the countertops instead?what is the easiest way to go?alot of questions but i want to do it right and myself.thanks
Old 02-09-03, 09:10 AM
Bud Cline's Avatar
If you are doing a countertop only then sheetrock is NEVER used in countertops.
As far as replacing any underlayments it just depends on how much damage you do getting the old off.
I would strongly suggest you use cement board as an underlayment and not apply your tile directly to any plywood.
You could "float" the countertops but it is a lot of work and isn't really necessary.
Old 02-09-03, 10:04 AM
erikk
bud,thanks for the help!!!
Old 02-09-03, 10:07 AM
erikk
hey bud,new question for you.if the plywood is 3/4 inch thick,how thick should the cement board be?
Old 02-09-03, 10:33 AM
Bud Cline's Avatar
Cement board is only available in two thicknesses, nominal 1/4" and nominal 1/2". The 1/4" would be sufficient for this application.
Technically it would be best to install the cement board in a bed of thinset and screw it into place. Follow the manufacturers directions.
Old 02-09-03, 02:44 PM
erikk
hey bud,thanks again for the help.you are making my job alot easer.
Old 02-09-03, 03:42 PM
Bud Cline's Avatar
Glad to be of help and Thank you.
