Old Tile Removal
Old 02-22-03, 12:06 PM
mitchpvh
Question Old Tile Removal
Any tips on removing 2X2 ceramic tile set with thinset from 3/4 in. plywood? Will heat help or just a hammer and 3 1/2" cold chesel is the answer?
Thanks,
Mitchell
Old 02-22-03, 12:31 PM
A
Hi
Heat won't do anything to the thin set.....your best bet would be a heavy scraper(once you get a section started). Now the thin set is a different story...no fun at all to remove off of plywood.
Old 02-22-03, 03:25 PM
mitchpvh
Remove old tile
Somehow I already knew that was the answer.......................
WJS_SR51
Some times you will have to remove the plywood too, if the thinset is very well bonded. What type of product do you intent to install next ? More information is better..........
Old 02-22-03, 07:45 PM
mitchpvh
Remove Old Tile
12X12 Daltile and from what I have read here, probable should put down a 1/4" underboard to adhere the new tile to........
Thanks,
Mitchell
Old 02-23-03, 04:44 AM
WJS_SR51
You could skim coat over the old thinset with new thinset and a flat trowell to smooth it over.
WJS_SR51
why not install the 12 x 12 over the 2 x 2
