Shower tile cleaning
Does anyone have any good ideas on how best to clean the grout in a shower? It is not real bad, however there are some places where the grout is becoming dark. Also, there are small areas where the grout is falling out. Can a white silicone tub & tile caulk be used satisfactorily?
You really should regrout those areas if the grouts falled out.
What color is the grout????
For cleaning "white" colored grout household bleach and a toothbrush bleach in a well ventilated area works well in removing mold and mildew. Rinse well with plain water afterwards then dry with a soft clean cloth (old towel).
If the grout is any other color than "white" then DON'T use bleach or the color will fade. Instead, you might want to try some other type of cermic tile cleaning product that specifically lists it's safe for colored grout. And by all means, don't use any type of acid based clearers since acid can etch or pitt the ceramic tile face, if used over time.
Grout repair
Cracked and missing grout should be removed and replaced. Once grout has been replaced or cleaned, keep sealed with penetrating sealer. Grout tends to be porous and absorbent of oils, soils, and stains.
NO ADVERTISING IN FORUMS
Cleaning Grout
It is not necessary to remove grout just because it has gotten dirty!!!
It is also not neccessary to use bleach!!
Instead of bleach, use a paste of OxyClean held in place on the walls by a piece of plastic that is taped over the past.
Look for a tile cleaning person in your area that uses a vapor system.
They can clean your grout with hot water vapor and make it look new.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
This thread has been edited.
Advertisements within the forums is not allowed.
Ads, advertisements, solicitations to buy or sell products, services or solicitations to hire a person, company to do work are not allowed within the forums.
Advertisement Policy and Disclosure Statements:
This forum topic nor any other forum topic on this web site was not intended to be used as a public bulletin board for the free posting of ads, solicitations and or advertisements of any kind.
Forums and there topics where intended to be used to exchange helpful problem solving methods and solutions to questions and not intended to be used as a public advertisement bulletin board.
Unfit and inappropriate postings not relevent to the intent of this web site, postings containing ads, advertisements, solicitations or any such postings deemed as such by the host, administrator, moderators of the forums will be edited and or deleted without prior notice.
Kindly direct your advertisements to our advertisement department using the "receive advertising info" link provided on the bottom of every web page.
To solicit a contractor or company to perform services for you, please use the: "Get Matched with PreScreened Local Contractors" pictorial link provided on the top right hand side of every web page.
Do not use email communications to send ads, advertisements or solicitations to our members or moderators. Our members email addresses and Personal {PM} Message services are not intended to be used for advertisement or solicitations of any type.
Failure to comply with these policy rules, any part of the policy rules, will result in lose of membership privileges allowed on this web site.
If anyone has any objections to this policy, I encourage you to contact the web sites administrator directly and clearly state your objection.
The "Contact Us" link is provide below for your convenience.
