Cutting Tile
Old 05-15-03, 12:01 PM
JimSummer
Cutting Tile
I recently completed a backsplash tile project using 6 inch tile. I rented a commercial size wet saw to do the tile cutting, per recommendation of the dealer from whom I purchased the tile and supplies. Now, I have a need to cut a few more pieces of the same type tile, and would like to know if there might be another option for cutting in lieu of renting the large size wet saw. I have maybe 12 cuts to make, and it would be very time consuming and expensive to rent the saw again for just a an hour or so of work. Some of the cut dimensions may be inexact until I do the actual fitting, so it would be somewhat of a problem to pay a tile dealer to do the cutting for me. Thank you for your time and suggestions.
Old 05-15-03, 04:04 PM
D
if it is a straight cut you need H-D has a cheap tile cutter for about $20.00
