Tile shower shelf and seat
Old 05-17-03, 05:22 AM
bigbluedude2
Smile Tile shower shelf and seat
I am just about ready to start a new tile shower install in a completey renovated bathroom. Walls down to studs and all new supply and waste lines. New floor joists, subfloor, the works. I have laid about 300sq. of floor time in the house and done shower walls in the past without problems.
My plan is to put a walk in tile shower with a small shelf for shamppoos, soaps etc. Would like to put the shelf recessed into the shower wall instead of attaching it on the wall like a little cubby hole. Do I need to put PVC like liner under the tile in the shelf recess, kind of like a shower pan installation? I will slope the shelf floor a little for water runoff. Any other hints? How about a larger shelf in a shower so I can sit my tired hind quarters down after all this work and let the water soak the muscle pain away?
Old 05-17-03, 08:11 AM
floorman
if you are going to build the niche peice by peice i would highly reccomend putting some kind of waterproofing in there like schluter kerdi they also make a preformed niche that you can use without having to waterproof
Old 05-17-03, 05:46 PM
ee3
for a pre made, pre waterproofed niche in 5 size'e contact the Noble co. www.noblecompany.com
Old 05-17-03, 07:08 PM
LewMac
bigbluedude2,
I did exactly what you are doing last year to a small 3/4 guest bath with a shower stall, sink and toilet. I tiled the shower, including a total rebuild of the shower pan, walls, and tiled the floor and wainscoat on the walls. I used the niches from Bonsal. Go to ---> http://www.bonsal.com/tilepage.html?sid=1713 to see them. I special ordered them from a local tile distributor.
I also installed a small "Better Bench". They are available from a variety of distributors.
Hope this helps.
LewMac
Old 05-17-03, 07:20 PM
LewMac
Photos of project
Here's a link to a web page with photos of the project I mentioned above, to see if this is what you are looking for.
http://bellsouthpwp.net/w/l/wlmc/Our...Den%20Bath.htm
LewMac
Old 05-18-03, 07:38 PM
ee3
the niches from bonsal used to be made by the some co. that is now making them for Noble Co. they can be ordered direct from Noble.
