Marble floor !
Old 05-29-03, 06:58 PM
TAColletti
Marble floor !
Can I install marble onto an existing tile floor and if i can what kind of adhesive would work...
Old 05-29-03, 07:05 PM
floorman
as long as the tile are stuck good and there are visible signs of the install failing[grout lines cracking,tile chipped or loose] then mapei keralastic is what you want to use also consider the heighth factor toilet flange and doors you may just want tear out and start over
