tile backsplash input needed
Received 0 Votes
I have about 18 inches from the top of my countertop to the bottom of my cabinets. What would you all recommend for tile size? I could do 3 six inch tiles vertically, and with a small gap size, I would just have to trim a little off either the top or bottom row. If I went with 4 inch tiles, the spacing doesn't work out so good. Are there other sizes that would work perfectly for an 18 inch vertical span? Thanks!
not really,pick what tile you want and make sure the counter top is level,start on the counter and work up if level put the cut at the cabinet line.Unless there is a very small cut make it full at the counter,you wo'nt even see the cut at the cabinets unless you bend over to look
