Ceramic tile floor underlayment
Old 08-07-03, 06:14 PM
LKarl
I want to install 12" ceramic tile in a bathroom. I have partical board flooring covered with linoleum. There is some water damage around the toilet from a prior overflow. Do I need to rip the flooring before installing the tile? What is the proper way to fix the situation?
I am a novice.
Old 08-07-03, 06:23 PM
ee3
Depending on joist spacing ect , you should remove the linoleum and install either another layer of ply wood ,and/ or backer board.Do not set tile to partical board!!
