nail removal from concrete
Old 09-20-03, 06:30 AM
We removed carpeting from basement floor and will be installing ceramic tile. How does one remove the "nails" that held the wooden carpet strips down. they are inbedded into the concrete.Tried a hammer but took a chip of concrete out along with nail. Any suggestions on how to remove before installing tile.
Old 09-20-03, 07:32 AM
Jim Schnasa
Try hitting the nail on the side. A tap or two should losen it . You will still get some divots but they are no problem.
Old 09-20-03, 10:04 AM
The nails come out but remove a chunk of the cement/concrete now can i use the mortar that i'm using to lay the tile to fill in these holes or do i need to first use like a "topping" mix concrete to fill the holes and then tile over. I have used a pair of pliers to pull the nails holes are then about an inch in diameter.
Old 09-20-03, 06:36 PM
Jim Schnasa
Your thin set will fill in the divots.
