dried tile grout
dried grout on tile floor
I left the grout on a tiled floor to long, anyone how suggestions how to remove. It has been dried over a month.
In some spots a light haze and other spots heavy(mudlike)
Dried tile grout removal
Muratic acid is used in bricklaying to loosen (clean) excess mortar from the face (wall). It should work OK on excess grout --- should not hurt shinny tile; BUT, to be prudent, test whatever you use on area of less direct view.
TIP: Avoid using abrasive cleaners like Comet, Dutch Cleanser and steel wool on shinny tile and porcelean fixtures --- it might not be highly perceptible to the unaware person, but abrasive cleaner will degrade the slick surface, making it more receptive to dirt/scum.
OLD JOKE: There once was a chemist who discovered a chemical that would desolve absolutely anything --- problem was that he could not find a container to keep it in.
