installing ceramic tile over existing ceramic tile
Old 10-18-03, 07:49 AM
dazydoo
Question installing ceramic tile over existing ceramic tile
HELP!!!!!
The existing ceramic tile in my bathroom was installed with cement, however there are no boards between tile and floor boards so the cement 'wrapped' into the floor boards making removal of tile impossible without cutting the boards. Can tile be installed over tile???? If so, is there is a special technique??
Old 10-18-03, 05:19 PM
D
If the tile is well secured and there are no hollow sounding areas it can be done. If it is a glossy tile you are covering, scarrify the surface with an angle grinder. And use thinset, not glue.
Old 10-19-03, 10:05 AM
Use a high flex modified thin set. You can get Flex Bond at Home Depot.
