Dumb?#1.
I am in the process of installing laminate & ceramic in a condo. First off the floor seems to have a 3/8 layer of plaster on it is this enough for ceramic. This condo is on the 3rd floor. I dont know the width of joists, etc, can't see them. Do I need to install Cement board overtop or not.
Dell, you're up wayyy too early. Just hit the snooze button, my friend!
No one likes Gypcrete (except the people that sell it). Getting rid of it is always an option.
If it is Gypcrete and you're not chopping it out, Ditra over top is the way to go. It'll let any moisture out that may get into the Gypcrete. Sheet-applied membranes will only hold it in there.
i think what you have here is called elastocil,it is a light weight concrete that they us e for condos and apartments anything over 2 stories high is perfectly acceptable to go over as long as you use some sort of membrane such as mapei maplastic or similar product e.c.o. has one as well.Do you have a neighbor or someone on the third floor you can ask and see if they have the same thing in their unit if so, more than likely elastocil
