help: 13x13 tile patterns?
Old 11-27-03, 10:26 AM
judyg
Question help: 13x13 tile patterns?
I picked out some floor tile and wanted to do the hopscotch pattern. The tile I picked out has 13x13, 6x6, and 6x13 sizes. BUT, the pattern flyer I got at Home Depot is for 12x12 tiles.
Can I do hopscotch with the tiles I picked out, OR do I need to pick out another tile? Can anyone clue me on other tile patters using the 13x13 series in which the pattern appears to be broken up a little?
Thank you!
Old 11-27-03, 11:06 AM
floorman
the problem as far as i can tell is the 6x6 tile,they would almost have to be 6 1/4 or 6 3/8 to work out the joint size of the 13"tile othetwise you would have about a 1/2 joint in those tile to compensate for the 13" tile.Lay them out on the floor and see what you come with ,or get in touch with h.d. and see if they have a pattern sheet for the particular tile you have chosen
