Need product advice to fill gaps/cracks in ply B4 tile.
Old 01-10-04, 11:09 AM
AresChild
Question Need product advice to fill gaps/cracks in ply B4 tile.
I would like to tile our kitchen floor. We will be removing the cushion flooring. What product is best used to fill in gaps and cracks in ply?
Old 01-10-04, 11:41 AM
joseph craig
there are several kind)s of floor patching compounds ARDEX or feather edge by armstrong works well. make sure floor is sound clean and dry.
Old 01-10-04, 01:42 PM
ee3
there are also crack isolation membranes.
is your floor two layer of ply or one ,how thick,do you have room to add a layer of cement backer board?, what is your joist spacing,length?
Old 01-10-04, 06:39 PM
I personally won't set tile directly to plywood.
Also one must consider the movement the wood subfloor has. Too much movement and the tile installation will fail.
Will the structure support the added weight?
Old 01-10-04, 06:48 PM
T
Concrete underlayment board
Concrete underlayment board is recommended beneath tile. Any movement in subfloor will tend to result in cracked grout and possibly cracked tiles.
