Tile Underlayment
Old 02-11-04, 10:55 AM
K
Tile Underlayment
I am planning to install 12 inch tile on a newly constructed floor. The floor consists of 2 layers of 3/4 inch plywood. Do I have to use 1/2 inch cement board or can I use a thinner cement board?
Old 02-11-04, 12:46 PM
Dave_D1945's Avatar
Go with the 1/2" backerboard and make sure the two layers of 3/4" plywood are well fastened together.
Old 02-11-04, 02:03 PM
ee3
WHY NOT 1/4"?(backerboard) i would.
Old 02-11-04, 04:46 PM
rs0
1/4 " is fine since you have 2 layers of 3/4" sub you are supposed to have atleast 1 1/4" of underlayment for ceramic......so 1/4" will do fine for you......just remeber to spread thinset underneath before you nail it down
Old 02-15-04, 07:42 AM
awesomedell's Avatar
I'd agree with the 1/4" cbu being acceptable, do put down the thinset and use screws, not nails on the cbu.
Old 02-15-04, 12:19 PM
rs0
you can use nails with concrete subfloors they need to be 1 1/4" roofing nails if you read the label on the board it tells you that plus nails are cheaper than screws and if you have a roofing nailer its much quicker
