BAthroom floor
Old 02-28-04, 11:41 AM
T
New Member
BAthroom floor
How long after I lay tile can I work on the tile surface?...not Grout just stand and work on other parts of the room.....
Thanks
Old 02-28-04, 01:09 PM
Wait 24 hours.
Old 02-28-04, 05:15 PM
D
Depends on the thinset, some can be walked on as soon as four hours. Check the bag for further info.
Old 02-28-04, 09:57 PM
My experience with different mortars is limited, so I'm sure you're right Daniel. As a single data point, I just looked at a bag of Versabond that I had sitting around. It says, "Allow to cure for a minimum of 24 hours before grouting or light traffic, depending on termperature and humidity."
Old 02-29-04, 10:05 AM
floorman
just to clear the air here,they make accelerated setting thinsets for small jobs and repairs that you can use ,go to lunch come back and grout and do a tap dance on if you wanted to.
But back to the subject,if you are going to do this ,work over the tile i mean,better cover it up cause you don't want to get the grout joints full of crap that you'll end up sucking out later
