Subfloor on top of slab
Old 02-29-04, 10:50 AM
rozeltf
I am going to finish a porch (16'x20')that adjoins the main house. This porch has a slab floor that is approx 5 inches lower than the main house (which also sits on a slab). I plan on building up the porch floor with 2x4 joists shimmed to the slab. What should my subfloor system be prior to laying tile? Also, what would be the best way to insulate this space?
Thanks for your help
Old 02-29-04, 11:12 AM
floorman
has this porch been enclosed ? i assume so ,the subfllor needs to be 3/4 cdx plywood with a 1/2 layer of durock for the tile to sit on space these sleepers at 16" intervals and shoot to the floor.
If it were me i would use the syrofoam insulation that comes in 4 x 8 sheets and cut them down to fit in between.
Get you're tile and see how thick it is and allow the thickness of a peice of cardboard for the thinset and figure your floor thickness according to that.
If this has not been enclosed then we need to do things a little different
Old 02-29-04, 12:47 PM
rozeltf
Yes, this is an enclosed porch, with 3' fnd walls, previously unheated.
Thanks for the reply. I was hoping 1 layer of 3/4" would be adequate.
Old 02-29-04, 09:46 PM
KurtJensen
Might not be a bad idea to put down a 6mil poly moisture/vapor barier on top of slab under the rest of your material. Cheap insurance against moisture problems. :-)
