Tile wall to tile floor joint
Old 03-05-04, 07:53 AM
mark8076
It's my first time doing a tiled shower floor. The joint where the wall tile meets the floor tile, should I grout that or do I have to leave a gap and caulk it?
Old 03-05-04, 10:36 AM
Some might grout, but I would caulk.
Old 03-05-04, 03:43 PM
D
sanded caulk is the way to go. its in the tile section at the hardware.
Old 03-06-04, 12:22 AM
F-Student
if you know how to grout good, you wont need caulk
Old 03-06-04, 10:53 AM
awesomedell's Avatar
Wall to floor joints are always going to have a slight bit of movement, hence caulk is required for the joint. A good tile store will have caulk which matches perfectly to nearly any grout color.
Old 03-06-04, 11:43 AM
floorman
yea, wherever there is a 90 degree angle at two walls or floor and wall in a wet are weather you grout good or not you always want to cualk that corner cause when water is involved if there is a way in it will find it and reak all kinds of havoc,so better safe than sorry, and use 100% silicone also
