sealing new grout?
Old 03-10-04, 07:26 PM
Question sealing new grout?
hi
i just re grouted a shower area with ace hardware non sanded grout. does this have to be sealed, it said to mist lightly for 3 days before using?
thanks
Old 03-10-04, 08:06 PM
Yea, it would be good to seal it. But you'll have to wait a while. Check the directions on the sealer you buy. It'll tell you whether to wait 3 days or 3 weeks. It's a real PITA to seal walls though. Floors are a lot easier.
Old 03-10-04, 08:17 PM
sealing grout
how do you know what to use, the walls a pita, how do you do it?
just was seaching the net, never done it before with a floated grout, i think the last tiles we had put in our on bath a few years ago, nothing was done, whats the i do or don't problem if i don't seal?
Old 09-08-08, 11:23 AM
Question
As you can see this thread is a little old, but i have another bath wall to regrout, i have to scratch-remove all loose grout? , then do i clean it, before regrouting, if you can direct me? i did this once, memory short.
thanks
i found the link thanks
Old 09-08-08, 03:39 PM
HotxxxxxxxOKC's Avatar
Did you find your answer?
You will want to remove 3/4 of the grout and start over.
Old 09-08-08, 04:20 PM
Question
thanks
the entire area is not in need of it, i can only do the necessary spots i'd assume?
silly question?
thanks
Old 09-08-08, 04:33 PM
Yes, I was saying you need to remove 3/4 of the grout in that joint, not 3/4 of the entire area.
Old 09-08-08, 04:42 PM
Thumbs up
thanks, i thought you meant that, i didn see any reason, i needed to do the whole 3 walls , i did that before on the other one, that was a pain. but i didn remove that much grout either, and i think the finish look showed although it wasn't bad
thanks
Old 09-11-08, 02:14 PM
Question Glue/Adhesive removal on tiles?- floor
Hi
Other than a lot of scraping is, there a Glue/Adhesive removal product to use on tile? Some are small floor tile and i have a couple maybe 5 x 6 , the little ones i have 30-40 to clean.
thanks
Old 09-11-08, 03:54 PM
Glue on tile?
If it's residual grout or thinset, use a plastic putty knife and/or a stiff brisel brush will some soapy water.
Old 09-11-08, 04:52 PM
Question Cleaning Tile
Thanks
The 2 big ones have a glue looking substance, thick, they are the base wall tile
The other ones i soaked in water with a little soap , have not brushed them yet, i assume the diamond pattern on the back is the trowel pattern? The floor tile
Old 10-16-08, 02:57 PM
Question Do you seal pre mixed grout on walls same as other grout?
I used an Ace brand pre mixed grout to repair the 8 wall tile i replaced, it says the grout sets completely in 48 hours, says nothing about sealing. Should it be sealed?
thanks
i didn't need a 10 # box. that's all they had in non mixed.
Old 10-17-08, 07:13 AM
Received 4 Votes on 4 Posts
Premixed grout is not real grout. It's nothing more than caulk in a bucket with sand mixed in. No need to seal that stuff. It wasnt the best stuff to use in a shower area. Worst that happens is that if it doesnt hold up, you'll remove it and replace it with real grout. Best of luck.
Old 10-17-08, 08:13 AM
Anything premixed is a bad decision!!
Marketed to the unknowing DIY'ers. It is pure junk! Mix with water in a bag, is the real deal.
Old 10-17-08, 10:26 AM
Naturally i am not an installer, but if it is branded as nonsanded grout premixed and applies the same, as i did the non mixed 4 years ago on another unit, if it is not right then the banner ads and links should be removed from this site.
If i'm still alive in a year i'll let you know the results being we have been here 35 years already.
Maybe a campaign should be started to remove this from all the manufacturers
Old 10-17-08, 11:25 AM
LMAO. You are right about that. Ahh what we wont do for advertising money????
Old 10-23-08, 10:04 PM
Question
im wondering how your grout is going to match up if your only doing 75 % of the wall
