vinyl tiles over ceramic???
Old 08-27-04, 06:21 AM
Mimster
can this be done safely with out the peel and stick coming off the ceramic tiles?? if so what precautions should one take or floor prep. do i have to follow.
Thanks
Old 08-27-04, 05:49 PM
A
Yes it can be done, but it is a ton of work to fill all the grout joints and other imperfections on the floor. If you don't you'll see every bump and joint transfer through the vinyl. It's not something you can learn overnight...that kind of patching take a bit of experience to do well.
Old 08-29-04, 06:54 AM
floorman
This would require alot of patching and alot of sanding in between and you ,more than likely will not like the results.Peel and stick is marginal at best under the most perfect circumstances, and this is not one of them
