Cornering Wall Tiles
Old 09-03-04, 06:07 PM
Abyss
Talking Cornering Wall Tiles
Hello : ) I have just installed Durock cement board and am now tiling the walls with DalTile 4X4 tiles. I just wanted to know that when you do a corner can you over lap the side wall tiles with the main center wall tiles or should you keep a space tolerance on each connecting surface. Basically should I leave a complete gap in the corner for grout?
I have read allot about tiling and hall done a few smaller projects myself and would appreciate any pro tips for making the job perfect! Thank you : )
Old 09-03-04, 09:08 PM
tfox60
corner tiles
Hi,
The store where you bought the tile should be able to supply you with some bullnose tile that will match. If it isn't obvious how to use them, ask at the store. Most places are willing to help.
Good Luck!
TFOX60
Old 09-03-04, 09:16 PM
tfox60
corner tiles
Hi Again,
In rereading your question I am not sure whether you mean a inside or outside corner. The suggestion I gave is for an outside corner. For an inside corner run one side almost to the corner 1/8" gap is sufficent. Place the tile on the other wall at the same gap you are using for the rest of the wall.
Good Luck!
TFOX60
Old 09-05-04, 04:39 PM
Abyss
Talking
Outside corner. Thanks for info
