Cutting cermaic tile the cheap way
Old 09-08-04, 12:59 PM
hman2
I have repaired a wall in my shower and having replaced the tiles with an 1/16" gap the ole tiles don't fit up. I have a dremel, how would I make pretty straight cuts with this tool? Is there another way such as a glass cutter?
Old 09-10-04, 09:14 AM
COBALT's Avatar
If you're trying to get an acurate cut by ANY stretch of the imagination forget the dremel, and don't even bother with a snap cutter unless you have a good rubbing stone to flatten the cut once you've broken it.
Do yourself a favor and go rent a wet tile saw from your local home store or equip. rental shop for a few hours. Make all of your cuts at once, and then return the saw.
