Tumbled Marble Sealing
Old 11-16-04, 08:04 AM
MarkMA
Iím getting ready to tile a small bathroom floor (5íx5í) with 3x6 tumbled marble in a herringbone pattern. Iíve already put down the cement board in mortar and have the pattern lay out done, but I have a question as to sealing the tile. Iíve been told that I should seal each tile before I install, let them dry then install the tiles, grout and reseal. Does this sound right or should I just install the tiles, grout and seal? Iím worried about the grout/mortar getting captured in the crevasses of the tumbled marble...
Old 11-16-04, 12:22 PM
T
Don't bother sealing the tile until it's installed. While you don't have to seal it until after grouting, it will make the grout clean up much easier if you do. Also, don't expect to get the nooks and crannies perfectly cleaned out either. It is so labor intensive and it looks fine with the grout filling the holes anyway.
