Another Ceramic Tile Question
Old 11-25-04, 05:00 PM
Bookladyjkd
Question Another Ceramic Tile Question
Deleted question by poster. Sorry!
Old 11-25-04, 05:07 PM
floorman
Trying to re-use old tile is a real pain in the $#@.Some tile you can soak in water for a while and then scrape the old glue off ,and then scrape the grout off the edges of the tile and then replace.If the tile is already coming off the wall then there is a good chance you can do this if you don't break any of the other ones that are a little more adheared to what they are sitting on.
Try taking afew of these tile and put them in some warm water and let sit for an hour and see what happens when you try to scrape the glue off the back of the tile,if it is hard or next to impossible then throw them a way and come up with another idea cause it won't be worth the effort to them clean and re-use
