White grout changes color
Old 12-21-04, 07:24 AM
phil1023
I have about six grout lines (around different tiles) in the shower stall that have turned a rust color. I tried to get rid of the lines by wiping down with bleach and did not work. I have replaced with white premix grout. After about 30 minutes some of these lines have the same type of rust color as before that bleeds thru the grout. I have re-raked the grout lines, wiped them down, waited for them to dry and re-applied the grout and the same thing happens. I don't think there is any moisture behind the tiles (the area is about shoulder level) but who knows. Any suggestions?
Thanks
Old 12-21-04, 01:11 PM
Sounds like rust leaching from the fasteners used to install the backer board.
