Installing ceramic tiles in a motorhome
Old 01-27-05, 08:52 PM
Jimmb
I would like to know how I can install ceramic tiles in my shower/bathroom area inmy motorhome. The total area that would require ceramic tiles is about 15 sq feet. At the present time the floor is covered with linoleum. The linoleum can be removed if necessary. Under the linoleum is plywood. Can the ceramic tiles be bonded/glued to this plywood? would the plywood require any special preparation? What would one use to bond/glue the ceramic tiles to the plywood? What would one use to "grout"the tiles? The motorhome floor "flexes" somewhat when the unit is in motion. I know this can be done as motorhomes now have ceramics installed. The only thing is I can't find out how it is done. Thanking you in advance for considering my request,I remain,
Jimmb
Old 01-28-05, 11:34 AM
pgtek's Avatar
hi
well if you have 1,000,000,000 motorhome i would say yes
but most motorhome are flexible. i would not used ceramic tiles.
you might try a laminated flooring as a substitute
cheers
pg
