Replacing ceramic tile?
Old 02-03-05, 11:39 AM
Johnny P
When replacing ceramic tile can you still use the existing concrete board or should you replace it and start over?
Old 02-03-05, 05:35 PM
D
It depends. If the cbu is in good shape then you should be fine. If it has sustained a lot of damage replace it. Generally I just replace it, I'd rather do a good job once than return to do it right. That being said, I just pulled the tile out of a shower someone esle did and the cbu wasn't damaged at all and I just tiled over it again.
Bryan
