Cutting a hole in ceramic tile backsplash
Old 02-13-05, 05:42 PM
bvs
I have a ceramic tile backsplash in my kitchen and I'd like to add an electrical outlet in there.
I have been unable to figure out a way to cut a hole in this to fit in a remod box for the outlet. I'm having trouble drilling/cutting the tile.
What should I be using to do this?
Old 02-13-05, 08:12 PM
F
If you have some extra tiles, you're better off breaking a few tiles, cutting your hole for an electrical box, then retiling around it...........It's very difficult (if not impossible) to cut tiles w/o a water saw.
Old 02-14-05, 07:10 PM
A
Yeah, I know what you mean. Can't drill or cut through the stuff for the life of me even with carbide bits with a hammerdrill.
Easiest I've found is getting one of those $99 Home Depot benchtop tile saws with the 4" diamond blade. Just do a plunge cut from the backside of the
tile by lightly pushing the tile down on the spinning blade. Electrical box
cutout is easy since the 4 cuts are straight.
You can use that little tile saw for small jobs elsewhere, so it's a
good investment regardless.
Old 02-14-05, 07:12 PM
D
Angle grinder will cut what you need. Have someone hold a vacuum by the cutting to keep the dust down. Don't forget the safety glasses.
