ceramic tile over ceramic tile richie
Old 03-15-05, 04:58 PM
richie
Question ceramic tile over ceramic tile richie
I am doing a bathroom remodel, I had a small custom cabinet in a corner I removed. After removing it I found the tile was not under the cabinet. Since th e floor tile is about 20 yrs old and is the 1"x1" mixed color sheet type I don't think I can find any. I was told I could go right over the existing tile with new ceramic tile, the floor and existing tile are solid and there are no weak points. I think it may be easier to just retile, its only about 60 sq. ft. Can this be done and any suggestions on how. thanks
Old 03-16-05, 08:55 PM
Tileguybob's Avatar
As long as there are no cracked tile or loose grout, then clean the old tile of any soap scum, hair spray lacquer, dust, etc. Use a modified thinset for the new tile. You may need to replace the door saddle if the new floor height presents a problem there.
