Tiles laid directly to 3/4" subfloor?
Old 03-22-05, 10:17 AM
jmazur
hi all--
i'm new to the tile section, but have found literally 100's of helpful answers to the rest of my reno' project in the other forums.
i am now at the point where i am ready to floor my 5 x 9 bathroom (approximately 6' of floor)
the floor is 3/4" ply subfloor glued and screwed (every 4"), which is over tji 360's at 16" oc (with one extra in between the two middle joists for added support).
i'm wondering if i can install the tile directly to the subfloor or is that not advised?
and
what is the best tile size to use?
my old apartment had what i think was like 2" tile flooring....
any advice would be greatly appreciated.
thank you,
--j
Old 03-22-05, 04:31 PM
Tileguybob's Avatar
Hardibacker makes the claim you can put their cement board over 3/4" ply. I would do that at the very least. Setting on ply is risky business, you will get a much better bond to the cement board. You can go with small mosaic up to 12" porcelain.
Old 03-22-05, 07:32 PM
Tom McNall's Avatar
Like TGB says, you need to strengthen your floor.
As far as tile size, pick what you like
(sorry, links in signatures are not permitted)
Old 03-23-05, 05:43 AM
H
If you go with a larger tile size like 12" it will make your bathroom floor space look bigger.
Old 03-23-05, 06:19 AM
jmazur
Terrific!
Thanks for the 411 guys!
Hardibacker it is!
Perfect!
I really appreciate it!
thanks again....
am going to pick some up this weekend!!
