Set small radiator on slate?
Old 03-29-05, 04:36 PM
Big Julie
We're redoing a small bathroom, and will be putting in slate tile on the floor. Any problem with setting the small, four section radiator directly on the slate?
Old 04-04-05, 04:00 PM
Tileguybob's Avatar
Seal the floor first and let the thinset cure for a week so the floor is absolutely rigid. The weight of the radiator will not be a problem if the thinset has cured and you have the correct subfloor under the tile.
