grout left on tile over night
Old 04-17-05, 06:34 PM
what can i use to remove grout that was left on tile over night?
Old 04-17-05, 08:49 PM
A
Not a lot. Sulfamic acid crystals may get the surface layer off, but the grout joints will still be rough and uneven. If it's a small area of tile, you may want to think about removing the tile and starting again.
Old 04-19-05, 08:28 AM
D
Grout
Water and a plastic scrub sponge and a lot of elbow grease. IGrout takes 3 days to dry fully and you should still be able to clean it up.
Hopefully you are just talking about grout residue and not the actual piled on grout from applying it.
Old 04-21-05, 03:23 AM
Big Orn's Avatar
Let's say that he is...
Old 04-26-05, 07:02 AM
D
Grout
Even more elbow grease!
Old 04-27-05, 02:32 AM
Big Orn's Avatar
Thanks, dogman1953.
So, it can be removed without adverse affects?
Will the tile still have that "new" look?
Old 05-03-05, 08:41 PM
T
Try soaking a wash cloth (or towel if it's a big area) in vinegar, then apply wet cloth to tile and let sit. I can even get dired thinset off with vinegar and water.
Tina
