When do I apply sealer?
Old 04-18-05, 10:25 AM
E
I re-grouted my master bathroom stall shower. The grout package said that it would take 21 days for the grout to cure. Do I need to wait that long to caulk and apply sealer to the grout lines? Do I caulk before sealing the grout or seal the grout and then caulk?
Thanks!!
Old 04-18-05, 02:24 PM
D
You can caulk before grouting. Use caulk in each area where one plane meets another. You can get sanded caulk to match the color of the grout. If you grout the areas where one plane meets another the grout will crack. Seal the grout inb 21 days.
