toilet flang
Old 04-28-05, 12:54 PM
toilet flang
i layed tile over a cement subfloor so now the flang sits lower than the top of the tile. how do i bring up the flang so it is level with the tile? i am assuming it has to be even with the top of the tile for the toilet to sit right.also is there a way to put a new flang in? i have the old type.
Old 04-28-05, 02:09 PM
They make an extended wax ring for just what you need.
You can also double up regular wax rings.
Old 04-29-05, 12:41 PM
D
To add even more to your choices, you can buy flange spacers. Generally, the extended size wax rings are enough to do the job. You could replace the flange but that would be a fair amount of extra work with no real benefits.
Later
Bryan
Old 05-01-05, 12:48 PM
thank you for the answer
