Removing Granite On Walls And Cabinets
Removing Granite From Walls And Counters . Has Anyone Any Info On Removing Granite From Walls And Cabinets Without Destoying The Wall And Cabinet?
Depends on how it was installed, pry it off the walls first, if drywall, easier to just replace it, on the counters, carefully prying it up a little at a time from each end going towards the back should do it.
Why are you removing the granite and is this solid surface or tile?
