Help. Removing Vinyl Tiles to put on Ceramic Tiles
Old 05-24-05, 04:46 PM
mostrofsky
Help. I have removed the vinyl floor tiles and am now left with trying to remove the black glue underneath along with what I think is some sort of floor levelor in which it is on cement. Does anybody know a fast and efficient way of removing this. I tried a hot gun and I also tried hot water but it will take me forever. I appreciate any suggestions.
Thank you,
Michele
Old 05-25-05, 10:15 AM
T
Were those 9" tile removed?, that black adhesive is probably cutback and contains asbestos, don't sand or grind this stuff yet, are you sure about a leveler used before it was set over the slab?
Old 05-29-05, 06:31 PM
mostrofsky
I am sure it is a levelor and the adhesive I am sure is not asbestos.
