where to start [laying bathroom tile]
Old 05-25-05, 05:48 AM
I am in the process of refinishing our bathroom of a loder home. I am Just days away from tile and was wondering some of the process. i have doen tile befor but it has always been on concrete and 12X12 ceramic commercial tile.
1. should i put down a cement backer board or is the plywood over diagnal floor boards sufficiant.
2. my wife has picked out glazed ceramic 6in X 6in wall tile for the floor will that work?
3. will a sand grout scratch the tile and dill the finish?
4. if i put tile on the drywall as a baseboard is there any special prep i need to do first?
Old 05-25-05, 06:14 AM
JPicasso's Avatar
1)The experts will give you advice about the floor structure, but I do know that you will want 1/4" backerboard for the floor. How thick is the plywood?
2)Wall tile will NOT work on a floor.
3) Not unless you go crazy with the grout.
4) nope. stick it on brother.
Old 05-25-05, 06:19 AM
ok i will go for the backer board.
as for the tile i was going to use 1/4 inch spacers for the grout instead of butting them together. my consern is are they strong enough to be on the floor with people walking on them?
Old 05-25-05, 10:23 AM
T
1. You will need 1/2" plywood over the plank flooring, then 1/4" CBU.
2. NO, wall tile is for walls only, floor tile can be used anywhere.
3. Depends on the glaze, if high gloss, possibly.
4. Space them 1/16 to 1/8" off the floor and caulk that joint.
Find a good floor tile with a PEI rating of 4 or 5, that will look nice with the tile she picked out, use the 6x6s on the walls only.
Old 05-25-05, 11:44 AM
Thank you all. this has been the most helpful site ive found on the internet thus far.
