Pedestal Sink ????
Old 07-03-05, 04:44 PM
onie
Pedestal Sink ????
I'm planning to remodel one of my bathrooms. Floor will be ceramic tiles. Do the tiles go under the foot of the sink or just around it ? iI looks like it has to be bolted on the floor and the wall. What woulld be the correct way to do it ?
Old 07-03-05, 06:34 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
The sink base sits on the tile. Some pedestal sinks come with a bracket that has to be connected to the wall. Usually they have a variety of hole spacing so that you can hit a stud in the wall. If you cannot hit a stud, use the wing type fasteners. The base is usually anchored down with Tapcon screws if you have a concrete subfloor or if not, just drill through the tile and use a lag type bolt. Good luck.
