ceramic tile refinishing
have a ceramic tile floor that has been regrouted and cleaned with muratic acid solution but it still gets dirty almost by looking at it. the nice glossy finish it had originally is gone. Is there a way to refinish a ceramic tile floor?
Hi Dean,
My immediate thoughts would be that after the muriatic acid wash, the tile Would be dull. Prior to putting the floor back into use, you would need to re-seal it {as you have taken away its protection} So far as re-finishing a ceramic floor, I'm thinking you just missed the re-sealing step to adhere the "shine" to it.
Truly hope this helps
Dean: Try using our SKID SAFE Water Based Sealer/Finish. 2 applied coats followed by 2 more the next week will make your ceramic tiles look shiny as new ! The treatment will last for many years, and we guarantee it for 5 years!
Other benefits are it is easy to clean with just plain water in most instances, and the tiles are now HIGHLY slip resistant.
Major Account references available.
Also, see our GROUT COATING SYSTEM tm at our web site www.ndclean.com
We manufacture all our own proprietary specialty chemical products.
