Should I removed K3 board underlay
Old 07-12-05, 07:41 PM
gordchan
I removed old lino from bathroom, with K3 board as underlay. Can I put plywood on top of K3, then lay the floor tile ?
Please advise.
Thanks
Gordon
Old 07-12-05, 07:53 PM
T
Received 1 Upvote on 1 Post
K3 is particleboard and not a suitable substrate for ceramic tile. You will need to install tile over 1/2" concrete underlayment board.
Old 07-13-05, 12:52 PM
Tileguybob's Avatar
Pull out the particle board, replace with BCX plywood 1/2" thick, screwed to the original plywood layer then the cement board as stated above. BTW the cement board needs to be set in a bed of thinset to fill voids and airpockets then anchored with galvanized roofing nails or backerboard screws.
Old 07-13-05, 01:32 PM
gordchan
thanks
Gordon
gordchan
thanks
Gordon
