tile to ooden floor
Old 05-29-00, 11:24 AM
Guest
Post
if anyone cen give me a quick reply i would appreciate it!!! what are my choices and how do i choose a correct threshold that (joins?) or meets tile from the bathroom floor to wooden parquet t&g flooring in the hallway?
Old 05-29-00, 12:07 PM
Guest
Cool
[The operative word is "correct". It is more what is your preference and how much of a bump in the floor are you comfortable with.
Your choices are wood, metal, marble and maybe a few others. Metal is probably going to sit the lowest. Then there is the consideration of do you have to trim off the bottom of the door to accomodate the increased height of the threshold.
The installation is like another threshold, size it, cut out any required areas and install with glue, nails, screws, etc for the appropriate materials being used.
Best of luck.
